Is there any way to modify the notification email template for insight object automation.
the following is an example, is it possible to remove Reason and Matched
also is it possible to use object attributes inside the message, I tried using something like {{key}} but it did not work :(
Hi Reenad,
You can send custom notifications that include attributes of Insight objects using our app - Raley Emails Notifications.
Here's a link to our doc that explains how to do this.
Vladimir | Raley
