insight objects automation's notifications
Reenad Almayah
January 26, 2023
Is there any way to modify the notification email template for insight object automation.
the following is an example, is it possible to remove Reason and Matched
also is it possible to use object attributes inside the message, I tried using something like {{key}} but it did not work :(
Register today
