integration of jira with QuickBook
Rajesh Ramankutty
Hi guys,
I need to integrate quickbooks with jira soft for invoice purpose can anyone share me any documentation how to do it.
Gabe Kressel April 29, 2021
Hi Rajesh! I'd like to recommend you try out Skyvia if you use Quickbooks Online.
It is a web-based platform, which doesn't require coding knowledge. Using Skyvia you can schedule the process of loading data from Jira Cloud Platform to Quickbooks Online and vise versa: https://skyvia.com/data-integration/integrate-quickbooks-jira
Anton from HelloClerk_io
Hi, @Rajesh Ramankutty
You can try the Clerk Invoices Jira app. It helps generate invoices from Jira and Tempo worklogs and export them to QuickBooks. So, it does exactly what you need.
I'm the developer of this app, so you can ask me any questions!
Angélica Luz
January 2, 2020
Hello Rajesh,
I've searched for a documentation and add-ons on our marketplace, but there is no option to integrate Quickbooks directly from Jira.
There is a third-party app that may help you to integrate:
Hope this helps!
Angélica
