Hi Team,
Can we integrate Jira Server(on premise) with GitHub Enterprise Cloud ?
Hi Aneesh,
This is Majid @ Exalate.
You have a few options when it comes to connecting these two, but depends on the exact use case that you are looking to address. Please have a look at Exalate that helps to sync issues and PRs from GitHub to any Jira flavour.
Hope it helps!
Majid
Hi Aneesh,
There are multiple integration tools available to integrate GitHub with Jira. Depending on what all you are looking to integrate and what scale, sync tools can be divided into the following categories:
OpsHub, an Atlassian partner with a certified integration tool, can help you integrate GitHub issues and history of development, like Commit Information, Pull Request, etc., to a Jira project. You can look at the demo video to learn how OpsHub Integration Manager facilitates bidirectional integration between GitHub and Jira. Also, you can read our exclusive guide on Jira GitHub integration.
Feel free to reach out to us for your integration planning.
Brad
@Aneesh Sreedharan hello. Feel free to explore ZigiOps. It can connect the two instances, sync them and keep them updated in real-time (if that's what you want). You can easily customize it without a single line of code. You can try ZigiOps trial version to see what it's capable of.
Regards, Diana (ZigiOps team)
Sorry, the Jira version I'm using is Enterprise Data Center Jira instance V8.7.1.
So, can we Integrate Enterprise Data Center Jira with GitHub Enterprise Cloud?
Probably.
The problem is the term "integrate", what does that mean exactly. You could integrate anything with everything and it can be a different functionality every time.
I mean just a search for "jira github integration" is pretty bountiful in search engines.
I got the procedure to integrate Jira Cloud with GitHub Cloud or GitHub Enterprise Cloud(Integrate with GitHub Cloud | Atlassian Support)
In the similar fashion, whether we can do it for Jira Enterprise Data Center with GitHub Enterprise Cloud ?. Hope you understand.
And the answer is yes, depending on what you want to integrate and how.
I think "Integrate Jira with GitHub Cloud" is a straight forward question..
only doubt is whether Jira Enterprise Data Center can be integrated with GitHub Enterprise Cloud. I know Jira cloud can be integrate with GitHub Cloud. But not sure about Jira Enterprise Data Center version.
