invoking ActiveObjects before <ao> configuration module is enabled or plugin is missing an <ao> conf
Vishwajeet Singh
I am developing a jira service to store records in ao table . My table is created just fine but when I am trying to execute below code in service I get this exception
invoking ActiveObjects before <ao> configuration module is enabled or plugin is missing an <ao> configuration module. Note that scanning of entities from the ao.model package is no longer supported
ao.executeInTransaction(new TransactionCallback<Cust>(){
@Override
public Cust doInTransaction()
log.info("Pushing Customer : " + customerName);
final Cust customer = ao.create(Cust.class);
customer.setCustomerEmail(customerEmail);
customer.save();
log.info("Saved Customer : " + customerName);
return customer;
Does ao works in service module ? If so is there any thing additional required .
I have added entity in atlassian-plugin.xml .
Vishwajeet Singh
I have managed to resolve this using https://www.j-tricks.com/tutorials/active-objects-injection. Looks like only plan C works inside a service.
Saurabh Gupta February 25, 2021
This helped me understanding the problem.
Like Nikolai Nekrasov likes this
Sooxin August 27, 2022
I met this error, too. And I finnally find the problem is that the field name (getter) is too long for AO.
Saurabh Gupta March 1, 2021
Like anhnnp likes this
