Sign up Log in
is Jira 5.2 compatible on IE11???
Jayesh Baviskar
September 1, 2015
Jira 5.2 compatible on Internet Explorer 11
teilor_soares
September 2, 2015
Hi Jayesh!
Nic is right, just complementing his answer, you can find all supported platforms for 5.2 in the link below:
https://confluence.atlassian.com/display/JIRA052/Supported+Platforms
Cheers!
Teilor
Nic Brough -Adaptavist-
September 1, 2015
No.  Only IE 8 and 9.
It might work ok, but it's not supported, so if you have problems, the response is going to be "upgrade"
