is it possible make default value of select issue filed when issue changes status and popup screen
Виктория
is it possible make default value of select issue filed when issue changes status and popup screen coming up?
I tried it in behaviours ... but it doesn`t work
def issue = Issue.getByName('Development type') . transition('Design')
if (issue.getValue() == "") {
issue.setFormValue('Low Code')
March 20, 2023 edited
Hi @Виктория
If you intend to set the default value for the list, a sample code is available in the Adaptavist Library.
Below is the sample code for your reference:-
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
// a single select list custom field name
final String fieldName = "Select List"
// the value to set
final String setValue = "Some Value"
def field = getFieldByName(fieldName)
def optionsManager = ComponentAccessor.optionsManager
def customField = ComponentAccessor.customFieldManager.getCustomFieldObjects(issueContext.projectId, issueContext.issueTypeId).find {
  it.name == fieldName
assert customField : "Could not find custom field with name $fieldName"
def fieldConfig = customField.getRelevantConfig(issueContext)
def options = optionsManager.getOptions(fieldConfig)
def option = options.find { it.value == setValue }
assert option : "Could not find option with value $setValue"
field.setFormValue(option.optionId)
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Please also note this should be done using the Behaviour Initialiser.
To do this via Server-Side Behaviour, you must not initialise the field using the Field Name. Instead, it would be best if you declare it as:-
def field = getFieldById(fieldChanged)
This ensures that the Behaviour will only take effect if you have made any changes to that field the Server-Side Behaviour has been configured for.
But since you want to set the default value when the Create or Edit screen is loaded, the Behaviour Initialiser is the best approach.
I hope this helps answer your question. :-)
Thank you and Kind regards,
Ram
Виктория
@Ram Kumar Aravindakshan _Adaptavist_
you lost issue status,
i need it in poop up window when transit from status "design"
you example do it like always when issue create i need this field empty
March 21, 2023 edited
Hi @Виктория
Thank you for providing the clarification.
If you intend to set the value for the Multi-Select List on a Transition Screen, all you have to do is:-
@BaseScript FieldBehaviours behaviours
def multiSelect = getFieldByName('Sample Multi List')
if (actionName == 'In Progress') {
multiSelect.setFormValue(['Sample 1'])
Please note that the sample code above is not 100% exact to your environment. Hence you will need to modify it accordingly.
Before adding the code above, it would be best to do basic logging to determine the action name. You will need to add the logging below:-
log.warn "============>>> ${actionName}"
In my environment, the actionName returns In Progress. Hence, I am using 'In Progress' in the if/else condition shown in the code above.
You must use the Behaviour Initialiser when using the code above for it to work as expected.
Below is a screenshot of the Behaviour configuration:-
Below is a screenshot of the workflow that I am testing with:-
I am also including a couple of these screenshots for your reference:-
1. First, I create a sample issue of Bug-type as shown in the image below:-
2. Next, I transition the issue to In Progress, as shown in the image below:-
3. When the transition takes place, the dialog pops up, and in it, the Multi-Select List has been set to the default value Sample 1, as expected.
I hope this helps to answer your question. :-)
Ram
Виктория
like this it doesn`t work
I do use the Behaviour Initialiser
where in code i need to put this ?
log.warn "============>>> ${Design}"
Hi @Виктория
In my previous comment, I have already mentioned:-
You need to modify the code accordingly and not just copy and paste the code.
In my environment, my multi-select field is called Sample Multi Select. You need to change the name according to you environment. Similarly, the multi-select options that I am using is also different,  you will need to modify this as well.
Regarding the log, as I mentioned, before  using the sample code below in the Behaviour Initialiser. Do not change this code.
If you try and use the approach below, it will not work
The screenshot that I have shared in my previous comment explicitly shows where the Behaviour Initialiser is located, i.e.:-
In the screenshot above, I have added the end code after I have determined what is the action name.
As I mentioned earlier, you will need to first add the log parameter and try to do a basic transition to see what is the actionName that printed out. Once you know what is the action name, you will need to modify the code and update action name condition accordingly.
I suggest reading through the Adapatavist Documentation first to get a better understanding on how to use the Behaviour Initiailser.
Ram
Виктория
 @Oday Rafeh
this works! thank you
Oday Rafeh
March 21, 2023
Greate, very happy to hear that
Виктория
March 23, 2023 edited
can we update code and make a check if field is empty?
Hi @Виктория
To answer your question, yes you can. You can include an if/else check like:-
multiSelect.clearError()
if (!multiSelect.value) {
multiSelect.setError('Value has not been set')
Below is the updated sample code for your reference:-
multiSelect.setError('Value hoas not been set')
Ram
Виктория
I just need to check that
Sample Multi List
has not beet set before, if it already has a value then to do nothing.
rules above not really works
Hi @Виктория
If you want to check whether the field has already been set, then you will need to use
if (multiSelect.value) {
return
 Your updated code should be like this:-
return
So if the multi-select field already has a value set for it, it will ignore it and not do anything.
I hope this helps to solve your question. :-)
Ram
Виктория
now it`s ignore this part
because if field like empty it`s value "none"  what the code translate
Hi @Виктория
Sorry, I missed out the None value.
I have tested the updated code below, and it works as expected:=
if (underlyingIssue) {
if (multiSelect.value != [null]) {
return
If any value other than None is set for the Multi-Select list, it will not update. If the value is None, it will automatically set it to Sample 1.
Also,  using the if(underlyingIssue) will ensure that the validation is done once the issue has already been created, i.e. for the Issue transition screen.
Ram
Oday Rafeh
March 20, 2023
Hi @Виктория ,
Seems to me that you are using Adaptavist ScriptRunner ( Please mention the other name if it's not)
So if yes you need to create a ScriptRunner behaviour.
I can help you with the steps, if you want help with this let me know.
Regards
Oday
Виктория
@Oday Rafeh
that is write.
help please
Oday Rafeh
March 20, 2023
Okay fine @Виктория
The correct approach to set a default value for the 'Development type' custom field during a transition:
  • In Jira, go to 'Manage apps' and then navigate to 'Behaviours' under 'ScriptRunner. '
  • Click on 'Create Behaviour' and give it a name and description.
  • Click on 'Add Mapping' and select the transition screen you want to apply the behaviour to.
  • Add a new server-side script for the 'Development type' field:
def developmentTypeField = getFieldByName("Development type")
// Replace 'Low Code' with the default value you want to set
def defaultValue = "Low Code"
if (developmentTypeField.getValue() == null) {
developmentTypeField.setFormValue(defaultValue)
Save the script and behaviour.
Let me know if this helped.
Виктория
@Oday Rafeh
Oday Rafeh
March 20, 2023
@Виктория
Can you try this :
def issue = underlyingIssue
def issueStatus = issue.getStatus().name
// Check if the issue is transitioning from the "Design" status
if (issueStatus == "Design" && developmentTypeField.getValue() == null) {
Виктория
@Oday Rafeh
looks good but doesn`t work((
ir is select list single choose
Oday Rafeh
March 20, 2023
@Виктория it seems that you want to set the default value only during the transition, not while the issue is in that status.
if (getAction()?.name == "your_transition_name") {
Can you check this ?
Виктория
@Oday Rafeh
nope... same no results...
Виктория
@Oday Rafeh
may be any other options?
Oday Rafeh
March 21, 2023
Hi @Виктория , Sure I will keep help to we can find a solution
Please try this script :
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.workflow.TransitionOptions
import com.atlassian.jira.workflow.WorkflowTransitionUtil
// Name of the select list custom field
// Default value to set
final String defaultValue = "Default Value"
def issueStatus = issue.getStatus().getName()
// Check if the issue is transitioning to a specific status
if (issueStatus == "Target Status Name") {
// Set the default value for the select list field
def optionsManager = ComponentAccessor.getOptionsManager()
def customField = customFieldManager.getCustomFieldObjectByName(fieldName)
def fieldConfig = customField.getRelevantConfig(issue.context)
// Find the option for the default value
def option = options.find { it.value == defaultValue }
// Set the default value for the field
if (option) {
// Continue with the transition
WorkflowTransitionUtil workflowTransitionUtil = ComponentAccessor.getComponentOfType(WorkflowTransitionUtil.class);
IssueInputParameters issueInputParameters = workflowTransitionUtil.createIssueInputParameters(
issue,
fieldBehaviours.getModifiedFields()
TransitionOptions transitionOptions = new TransitionOptions.Builder().skipConditions().skipValidators().build()
workflowTransitionUtil.progress(issue, issueInputParameters, transitionOptions)
 Let me know the results please
Виктория
 @Oday Rafeh
no good results...
and look like a mistakes in code (red lines on right side)
Oday Rafeh
March 21, 2023
@Виктория
It looks like the issue is related to unresolved dependencies. Try adding the following import statements at the top of the script:
import com.atlassian.jira.issue.context.IssueContextImpl
import com.atlassian.jira.issue.fields.config.FieldConfigScheme
import com.atlassian.jira.issue.fields.config.FieldConfigSchemeManager
import com.atlassian.jira.issue.fields.config.manager.FieldConfigManager
Then, modify the code for setting the default value of the select list field as follows:
def options = optionsManager.getOptions(customField.getConfigurationSchemes().find {
it.getOneAndOnlyConfig().getId() == fieldConfig.getId()
}.getOneAndOnlyConfig())
if (option) {
field.setFormValue(option.value)
Виктория
@Oday Rafeh  nope, still doesn`t work...
may be need to create behaviours to the custom screen what I use for transition?
Register here ⬇️
