is it possible to add a variable to a filter?
t March 31, 2015
i have a filter and i want to have a 'date picker' as a variable for anyone who wants to change the date range the filter is for, however this dashboard is for read only, no one will be logged in.. is this possible?
t April 6, 2015
There is a field 'landline' which i have a filter set to startofday to control this field, however i am needing this date to be changed not on a permanent basis just read only so that anyone who doesnt have a JIRA account can still go my JIRA website and have preloaded dashboards (i think i need about 5) which simply show anything with date in the landline field however for that specific date that they are wanting to see.
Date range would be probably just a month behind till todays date however default to anything with todays date as landline date
jose_castro
Hello Thomas,
  • Can you clarify a bit more what this date range is based off of?
  • The dashboard would be read only yet you would like users to be able to specify a date range correct?
  • If you can provide the above I create the filter on my end and provide you the configuration steps.
Ramiro Castro
Support Engineer
Atlassian
t April 15, 2015
are you able to assist any further? :)
Help us plant more trees
