I need get user email address from jira project Role,Assignee,Watchers,ProjectRole. using java API.
I think this will be a two step process. First, get the User-Names from your sources using the relevant API calls like
https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/#api/2/issue-getIssue
https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/#api/2/issue-getIssueWatchers
https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/#api/2/role-getProjectRoleActorsForRole
Then using the usernames to get the email-address using https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/#api/2/user-getUser
Ah, sorry, my mistake.
For Assignee you need to get the Issue (https://docs.atlassian.com/software/jira/docs/api/7.12.0/com/atlassian/jira/issue/Issue.html), then you can get the Assigne with getAssignee, you can get the email-address the from the resulting ApplicationUser.
To get the Watchers, you can use the WatcherManager https://docs.atlassian.com/software/jira/docs/api/7.12.0/com/atlassian/jira/issue/watchers/WatcherManager.html
And for ProjectRole, please check the ProjectRoleManager https://docs.atlassian.com/software/jira/docs/api/7.12.0/com/atlassian/jira/security/roles/ProjectRoleManager.html, there you will get the project roles, the you can get the ProjectRoleActors and from there the Users.
For Groups, use GroupManager https://docs.atlassian.com/software/jira/docs/api/7.12.0/com/atlassian/jira/security/groups/GroupManager.html
