is it possible to hava a table with jira issues where each cell is a sub table depending on result
Jens Jensen August 29, 2019
Hi.
Anyone know whatever its possible to make a table with inbedded tables in each cell depending on the result from the first JQL.
What I want to achieve in confluence is.
Make a JQL Query that shows all products that are scheduled for a release. Show the name in the first cell.
In the second cell I want to show all stories connected to that product that are scheduled to be released in that release.
In the third cell I want to show all open bugs in that product.
Etc etc.
So it will look something like this
Product                     User stories                 Open bugs
Product A                       US1                         Bug1
                                      US2
Product B                       US1                         Bug2
        Bug3
Product C                       US3
Is this possible, and if so, how.
Best regards,
Jens
Yevhen Rohovets
September 2, 2019
If I understood correctly, you need to create a Scrum board with swimline. Each swimline can have self JQLm so you can do everything.
Please check this article from Atlassian
And one topic about this subject, maybe it helps to you https://community.atlassian.com/t5/Jira-Software-questions/I-need-JQL-for-customizing-Swimlane-to-group-by-Custom-Field/qaq-p/659294
