Hi Andrea
You can use ScriptRunner Behaviours module for this. You can find a similar example at
https://scriptrunner.adaptavist.com/4.3.0/jira/recipes/behaviours/setting-default-fields.html
For example, if I have the below custom fields, can the the summary be concatenation of the fields so the summary/title issues is standardized?
Environment = Prod
CR = CR207
Priority = Medium
Then Summary would read concatenate(Environment: CR, priority) to be "Prod: CR207, Medium"
Hi Andrea.
I don´t understand what you´re trying to do! could you give an example?
