AUI Dropdown has a data-dropdown2-hide-location attribute which can be used to explicitly set where the drowdown is hidden. By default it is hidden in the original location. With inline dialog it is strangely much worse. There is no such attribute (according to docs) and by default dialog gets hidded outside body, which makes it impossible to use inside dynamically loaded and reloaded elements, because dialogs outside are not getting cleaned, so they get duplicated and broken.
Is there a way around it or maybe there is an undocumented attributes like in dropdown?
