is there an indicator of an attached document(s) that we can use in the issue query tool?
alan lippa February 7, 2013
is there an indicator of an attached document(s) that we can use in the issue query tool cause when I write the issue query there is no attached or documentation or anything I can find to pick off a jira ticket that has documentation attached to the jira item.
thanks for your help
low priority on this.....Al Lippa
Marcus Silveira
February 8, 2013
Hi Alan,
You can install JIRA Toolkit Plugin to add the custom field 'Number of Attachments'.
Then you'll be able to search for issues filtering by issue s with 'Number of Attachments' > 0.
Hope this helps,
Marcus
Orit Nachshon
Anything new in Jira OOB on this question?
alan lippa February 13, 2013
accepted however reading the high level documentation and customer feedback was challenging in that it does nto appear that this functionality went forward....thanks very much for the response.
