issue event listener
mehran haghani
when i implement my class from IssueEventListener and impement its methods not happening on issue events. how i can listen to issue events in my class ?
dose my class called even if issue events occures in another page?in the other hand how i can use issue listener to run my class on issue events?
thanks a lot
tis is my simple class code:
package com.atlassian.jira.event.listeners;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.event.JiraEvent;
import com.atlassian.jira.event.issue.AbstractIssueEventListener;
import com.atlassian.jira.event.issue.IssueEvent;
import com.atlassian.jira.event.issue.IssueEventListener;
import com.atlassian.jira.event.user.UserEvent;
import com.atlassian.jira.event.user.UserEventListener;
import org.ofbiz.core.entity.GenericEntityException;
import org.ofbiz.core.entity.GenericValue;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
public class my class extends IssueActionSupport implements IssueEventListener
public void customEvent(IssueEvent arg0) {
// TODO Auto-generated method stub
public void issueAssigned(IssueEvent arg0) {
public void issueClosed(IssueEvent arg0) {
public void issueCommented(IssueEvent arg0) {
System.out.println(arg0.getIssue().getKey() +"comment");
public void issueCreated(IssueEvent arg0) {
public void issueDeleted(IssueEvent arg0) {
public void issueGenericEvent(IssueEvent arg0) {
public void issueMoved(IssueEvent arg0) {
public void issueReopened(IssueEvent arg0) {
System.out.println(arg0.getIssue().getKey() +"reopen");
public void issueResolved(IssueEvent arg0) {
public void issueStarted(IssueEvent arg0) {
public void issueStopped(IssueEvent arg0) {
public void issueUpdated(IssueEvent arg0) {
System.out.println(arg0.getChangeLog().modified +"updated");
public void issueWorkLogged(IssueEvent arg0) {
public void workflowEvent(IssueEvent arg0) {
Onkar Ahire
November 23, 2013
Hi Mehran,
Go to JIRA Administration >> Listeners >> Add fully qualified name of your listener class
OR
in below code you did not required to add listener class explicitly.
public class MyEventListenerClass  implements InitializingBean,DisposableBean
	public MyEventListenerClass()
	public void afterPropertiesSet() throws Exception
		eventPublisher.register(this);
	public void destroy() throws Exception
		eventPublisher.unregister(this);
	@EventListener
	public void onIssueEvent(IssueEvent issueEvent) throws Exception
		Long eventTypeId = issueEvent.getEventTypeId();
		log.debug("On Issue Event against issue "+issueEvent.getIssue().getKey());
		if(eventTypeId.equals(EventType.ISSUE_CREATED_ID))
				// do stuff on issue created event
atlassian-plugin.xml
<component-import key="eventPublisher" interface="com.atlassian.event.api.EventPublisher"/>
			<component key="eventListener" class="com.ora.sm.MyEventListener">
		    <description>Class that processes the incoming JIRA issue events.</description>
	 </component>
Regards
Onkar Ahire
mehran haghani
thanks onkar , it works when i added my listener :)
Nic Brough -Adaptavist-
November 22, 2013
The basics of writing a listener, explaining how you get the information about the change that fired the event (including issue) is all at https://developer.atlassian.com/display/JIRADEV/Writing+JIRA+Event+Listeners+with+the+atlassian-event+Library
mehran haghani
My jira version is 3.7.2 Andy
Andy Brook [Plugin People]
November 22, 2013
This was the JIRA4.x way of doing things, see the tutorial Nic linked (and /or clarify your JIRA version)
