I am trying to find all issues in a particular project that have certain link states e.g "is depended on by".
There are no errors thrown with the filter I made and I do get a large list of results but I seem to get everything in multiple projects that has the blocks and dependancy links rather than just everything under a specific project listed in the query. Is the syntax incorrect or is there a better way to do this?
Thank you!
project = "XXX" AND issueFunction in hasLinks("is blocked by") OR issueFunction in hasLinks("required by") OR issueFunction in hasLinks("is depended on by")
Also tried:
project in ("XXX") AND issueFunction in hasLinks("is blocked by") OR issueFunction in hasLinks("required by") OR issueFunction in hasLinks("is depended on by")
Can you try like this:
project = "XXX" AND (issueFunction in hasLinks("is blocked by") OR issueFunction in hasLinks("required by") OR issueFunction in hasLinks("is depended on by"))
It should work.
