I have a REQUIRED single select customfield set for a given screen which is mapped to a given issue in JIRA.(the one i will be creating programmatically). The value to be set for these fields is obtained from another dropdown in a transition screen.
When I try to create the issue programmatically using a jira plugin, it fails probably because a value is REQUIRED for the customfield(despite setting a default value for the field in JIRA) . If I dont make the field REQUIRED, i am able to create the issue and also update its value using
customField.updateValue()
after creating the issue.
But I want to keep the REQUIRED option else I cannot remove the None option from the dropdown.
Ive tried setting the value using the below code before the issue is created.
issueInputParameters.addCustomFieldValue(custFieldId,"value to set"); UpdateValidationResult update = issueService.validateUpdate(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), issue.getId(), issueInputParameters); if (update.isValid()) { issueService.update(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), update); System.out.println("Update is valid"); //It prints this }else{ System.out.println("Update is not valid"); } IssueLinkManager issueLinkManager = ComponentAccessor.getIssueLinkManager(); CreateValidationResult createValidationResult = issueService.validateCreate(user, issueInputParameters);
but createValidationResult fails and the issue is not created. Where am I going wrong ? Ive also tried using
issueInputParameters.setSkipScreenCheck(true)
but with no luck. Can anyone please help me to create the issue keeping the REQUIRED field option set.
Hi Komail! This looks like a developer question, so it would be better to post it at community.developer.atlassian.com that's where our developer community hangs out :)
Ana
Hi Ana, I've raised the same question there . I was using this forum earlier and got replies to my other questions regarding jira development, so assumed that its the right one :)
