issueService.validateTransition close Issue
David Boldt August 7, 2012
I can from the statuses: open, in progress, reopended modify to close with the issueService.validateTransition.
But i cant from Resolved -> Closed.
getErrorCollection say: .. look at the history .. * or so
But there is no helpful information.
B.J. Herbison October 17, 2013
I think I'm seeing the same issue. When trying to transition to Resolved or Closed in the default JIRA workflow from a plugin I get:
It seems that you have tried to perform a workflow operation (Resolve Issue) that is not valid for the current state of this issue (ZZZ-123). The likely cause is that somebody has changed the issue recently, please look at the issue history for details.
There is no recent change in the issue. A reindex didn't help.
Radu Dumitriu
August 8, 2012
I think they do not have enough info.
David Boldt August 8, 2012
where are the atlassian specialists :(
