issues resolved before due date eazybi
Michael Blake May 25, 2016
I need a report that shows the percentage of issues resolved before their due date using fields duedate and resolutiondate.
Martins Vanags_eazyBI
Hi Michael,
With the help of eazyBI calculated measures, it is possible to create your expected calculation.
As I understand your question, you would like to create two calculated measures:
  • Issues resolved before due date (count of issues where resolution date is earlier than due date)
  • Issues resolved before due date % from all issues resolved ( count of issues where resolution date is earlier than due dated divided by count of all resolved issues
You could use formulas below. But be aware of calculated measure names in formulas.
Please also find documentation how to create calculated members in eazyBI:
Issues resolved before due date:
 NonZero(Count(
    Filter(
      Descendants([Issue].CurrentHierarchyMember, [Issue].[Issue]),
     [Measures].[Issues resolved] > 0
     AND
      DateDiffDays([Issue].CurrentMember.get('Resolved at'),
        [Issue].CurrentMember.get('Due date')) > 0
Issues resolved before due date % from all resolved issues:
CASE WHEN [Measures].[Issues resolved] > 0
THEN
  [Measures].[Issues resolved before due date] /
END
Please contact support@eazybi.com if you have further questions regarding this!
Martins Vanags / support@eazybi.com
Katherine-Anne Jansen May 25, 2016
You may be able to create a calculated field for Overdue and use that for your pie chart (which will give you percentages)
