When i create a workflow, assign it to a project. it asks to define the issue types. So i select 3 types. bug, feature, improvement.
This is added correctly. when i remove the second workflow from that project, so my new workflow only remains, it suddenly changes the selected issue types to all issue types.
this seems like a bug or am i doing something wrong here ?
kind regards,
Kurt
Hi @Kurt Callebaut ,
This is the native behavior of jira.
If you have 4 issuetypes, 3 issuetypes are using 1 workflow and 1 issuetype is using 1 workflow.
If you remove one of the workflows from them then the other issuetypes will be auto-assigned to the remaining workflow. Since there is no other workflow for the issuetype in the project it will use the other workflow.
Sravya
Thx for the reply, Sravya. Seems a bit unlogic to me, But the good news is i figured out that it can be solved by creating an issuetype scheme and assigning it to the project. It seem to overrule the issuetypes in the workflow.
