it is posible to change HTTPS links (IP,URL) base URL from config files (type XML) ?
I Wonder if it is posible to change HTTP links from config files ( not from JIRA or confluence )
the base url can be only perform from the application itself or from database level. Those xml files would only allow you to make changes on the tomcat connectors to accept https connection, keystore configuration of your SSL or additional network config such as proxy.
actually I want to change Base URL and app LINKS no context path, context path is not the IP, or complete URL isn't ? I mean from there I cannot change all the address,
I must use always JIRA / Confluence ? to change these things isn't ?
If you're looking to change context path for JIRA, you can do so by modifying the server.xml file in conf folder. Look for the line below:
<Context path="/jira" docBase="${catalina.home}/atlassian-jira" reloadable="false"> </Context>
Referring to this guide might help.
https://confluence.atlassian.com/display/JIRAKB/How+to+change+the+JIRA+context+path
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
