java.lang.NoClassDefFoundError: com/atlassian/jira/JiraException
SAI KRISHNA December 5, 2017 edited
Hi all ,
I am getting this error  for custom plugin
Sai Krishna
Aleksandr Zuevich
December 5, 2017
Hi, usually such error are due to dependencies inconsistencies. What is the scope of your jira-api dependency in your pom.xml? Is it provided?
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
Aleksandr Zuevich
December 5, 2017
When do you get this error? Do you extend JiraException in any own class?
when I trying upload plugin or enabling it  . no I am not extending JiraException
SAI KRISHNA December 6, 2017
Hi Aleksandr Zuevich ,
Can you please help me to fix the error .
Sai Krishna
Aleksandr Zuevich
December 7, 2017
I'm afraid we can't get definite help without your sources.
My assumption: it's due to dependencies. Maybe you use some library which is dependent on other library contains JiraException class.
aas
September 9, 2020 edited
I have the same problem is any solution? Try to use jql query in my Issue tab plugin and have
java.lang.ClassNotFoundException: com.atlassian.jira.issue.search.SearchException not found by com.jira.plugin.IssueTab.Panel
Get Certified! ✍️
