java.lang.NoClassDefFoundError: javax/servlet/ServletContext
mostafa jamareh September 25, 2013
when i run plugin using atlas-run command i give this exception on my atlassian-jira.log
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:679)
Caused by: java.lang.NoClassDefFoundError: javax/servlet/ServletContext
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2482)
at java.lang.Class.privateGetPublicMethods(Class.java:2602)
at java.lang.Class.getMethods(Class.java:1457)
at java.beans.Introspector.getPublicDeclaredMethods(Introspector.java:1303)
at java.beans.Introspector.getTargetMethodInfo(Introspector.java:1177)
at java.beans.Introspector.getBeanInfo(Introspector.java:409)
at java.beans.Introspector.getBeanInfo(Introspector.java:175)
at java.beans.Introspector.getBeanInfo(Introspector.java:238)
at java.beans.Introspector.<init>(Introspector.java:390)
at org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:220)
at org.springframework.beans.CachedIntrospectionResults.forClass(CachedIntrospectionResults.java:144)
at org.springframework.beans.BeanWrapperImpl.getCachedIntrospectionResults(BeanWrapperImpl.java:252)
at org.springframework.beans.BeanWrapperImpl.getPropertyDescriptorInternal(BeanWrapperImpl.java:282)
at org.springframework.beans.BeanWrapperImpl.isWritableProperty(BeanWrapperImpl.java:333)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1247)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
... 18 more
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContext
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:772)
at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 43 more
what is the reason of that ?
i'll be happy if someone can help me,
thanks in advance,
Bharadwaj Jannu
September 26, 2013
may be the container version bringing you the problem
you check https://answers.atlassian.com/questions/66628/weird-classnotfoundexception-during-startup-of-osgi-bundles if it may help
mostafa jamareh September 30, 2013
thank's ,Tomcat 7 isnt a supported platform for jira 5.0
Register here ⬇️
