I have a java script running in create page that calculate risks depending upon selected options of some select lists (these are the risk questions). All questions are mandatory, so user cannot escape without selecting any option in any those select lists. But the problem is, when someone does not enter value in any select list or in any other mandatory field and submits the page, the code stops working properly. I found the reason is that on page reload global variables are getting their initial values which is causing this. But how to either keep the final values of these variable while page is being reloaded or setting the initial options to all select lists?
Any help will be greatly appreciated.
<script type="text/javascript"> var q1 = document.getElementById('customfield_14254'); var q2 = document.getElementById('customfield_14255'); var q3 = document.getElementById('customfield_14256'); var q4 = document.getElementById('customfield_14257'); var q5 = document.getElementById('customfield_14258'); var q6 = document.getElementById('customfield_14259'); var q7 = document.getElementById('customfield_14260'); AJS.$(document).ready(function() { AJS.$("#customfield_14049").attr("readonly", true); }); q1.options[0].text = ' '; q2.options[0].text = ' '; q3.options[0].text = ' '; q4.options[0].text = ' '; q5.options[0].text = ' '; q6.options[0].text = ' '; q7.options[0].text = ' '; var q1_sel = -1; var q2_sel = -1; var q3_sel = -1; var q4_sel = -1; var q5_sel = -1; var q6_sel = -1; var q7_sel = -1; q1.onchange=function() { q1_sel = document.getElementById('customfield_14254').selectedIndex; q1_sel = q1_sel -1; calc_risk(); } q2.onchange= function() { q2_sel = document.getElementById('customfield_14255').selectedIndex; if(q2_sel==3 || q2_sel==4) { q2_sel=3; } else if(q2_sel==5 || q2_sel==6 || q2_sel==7 || q2_sel==8) { q2_sel=4; } else if(q2_sel==9 || q2_sel==10) { q2_sel=5; } //alert(q2_sel); q2_sel = q2_sel -1; //alert(q2_sel); calc_risk(); } q3.onchange= function() { q3_sel = document.getElementById('customfield_14256').selectedIndex; q3_sel = q3_sel -1; calc_risk(); } q4.onchange= function() { q4_sel = document.getElementById('customfield_14257').selectedIndex; q4_sel = q4_sel -1; calc_risk(); } q5.onchange= function() { q5_sel = document.getElementById('customfield_14258').selectedIndex; q5_sel = q5_sel -1; calc_risk(); } q6.onchange= function() { q6_sel = document.getElementById('customfield_14259').selectedIndex; q6_sel = q6_sel -1; calc_risk(); } q7.onchange= function() { q7_sel = document.getElementById('customfield_14260').selectedIndex; q7_sel = q7_sel -1; if(q7_sel != -1) { q7_sel = q7_sel +1; } //alert(q7_sel); calc_risk(); } function calc_risk() { var risk_score=0; var risk_Sum=0; var allQsSum = q1_sel+q2_sel+q3_sel+q4_sel+q5_sel+q6_sel+q7_sel; if(allQsSum != -7) { if(q1_sel>=0) { risk_Sum = risk_Sum + q1_sel; } if(q2_sel>=0) { risk_Sum = risk_Sum + q2_sel; } if(q3_sel>=0) { risk_Sum = risk_Sum + q3_sel; } if(q4_sel>=0) { risk_Sum = risk_Sum + q4_sel; } if(q5_sel>=0) { risk_Sum = risk_Sum + q5_sel; } if(q6_sel>=0) { risk_Sum = risk_Sum + q6_sel; } if(q7_sel>=0) { risk_Sum = risk_Sum + q7_sel; } } else{ risk_Sum = -7; } var risk_Sum = q1_sel+q2_sel+q3_sel+q4_sel+q5_sel+q6_sel+q7_sel; //alert("risk_Sum:"+risk_Sum); if(risk_Sum>=0 && risk_Sum<=6) { risk_score=1; } if(risk_Sum>=7 && risk_Sum<=12) { risk_score=2; } if(risk_Sum>=13 && risk_Sum<=18) { risk_score=3; } if(risk_Sum>18) { risk_score=4; } //alert(risk_score); if(risk_score > 0) { document.getElementById('customfield_14261').value = risk_score.toString(); } if(risk_Sum<0) { document.getElementById('customfield_14261').value = ''; } } </script>
Hi Indranil,
You probably load the script through AJS.toInit ... but you fail to load the script again when the page's content changes(e.g. page submits). You probably need to add the code on
JIRA.Events.NEW_CONTENT_ADDED
event. For more info see this guide
Peter
Register today
