jelly to create bulk projects
Saneth Kumar
We're using JIRA 4.3 and I need to create a large number of projects using the Jelly Runner.
Here's whats given in the documentation
<JiraJelly xmlns:jira="jelly:com.atlassian.jira.jelly.JiraTagLib">
<jira:CreateProject key="ABC" name="A Project" lead="a-user">
<!-- other jelly tags -->
</jira:CreateProject>
</JiraJelly>
However, I also need to assign the following schemes to each project. All projects use the same respective schemes
Issue Type Scheme:
Notification Scheme:
Permission Scheme:
Issue Security Scheme:
Field Configuration Scheme:
Issue Type Screen Scheme:
Workflow Scheme:
Is there a way to do this in one scipt?
I found this link that mentions how to associate a project to a workflow scheme, but it seems to be aimed towards JIRA 5.
Kailash Vasani May 14, 2013
<jira:CreatePermissionScheme> - for creating new permission scheme (works for jira 4.3)
RambanamP
December 17, 2012
The following code is not exact answer for you question but it should help you to start
To Create multiple projects and i added ony one for loop for project name and you have to add another forloop for project keys
&lt;JiraJelly xmlns:jira="jelly:com.atlassian.jira.jelly.JiraTagLib" xmlns:util="jelly:util" xmlns:j="jelly:core"&gt;
&lt;util:tokenize var="projects" delim=","&gt;projectA,ProjectB&lt;/util:tokenize&gt;
&lt;j:forEach var="project" items="${projects}"&gt;
&lt;jira:CreateProject key="ABC" name="project" lead="a-user"&gt;
&lt;!-- other jelly tags --&gt;
&lt;/jira:CreateProject&gt;
&lt;/j:forEach&gt;
&lt;/JiraJelly&gt;
Tim B December 17, 2012
Hi, have you been able to find a solution? I am looking for this too.
