jira 9.12 compatible postgresql version ?
xsus 365
May 28, 2024
I have installed jira ver 9.12 "atlassian-jira-core-9.12.8-x64" , what version of postgresql is compatible with jira 9.12. received message below
Troubleshooting and support tools
Problems detected
Warning
Supported Platforms
Warning
Supported database
What does this check do?
Checks if your Jira instance is using a supported database model and version. Using a supported database ensures Jira's data integrity and avoids unexpected behaviour when using Jira applications.
Result
PostgreSQL 16 is not supported. You should migrate to a supported database version.
Gikku
May 28, 2024 edited
@xsus 365 You can refer the Atlassian documentation for Jira 9.12 Supported platforms
According to the page, for Postgres versions 12,13,14 and 15 are only supported.
SERVER
VERSION
9.12
Get Certified! ✍️
