hi my jira address is https://203.120.121.167:8443/secure/Dashboard.jspa i want chage it to https://203.120.121.167/secure/Dashboard.jspa how can i do this. thanks and regards. |
(server.txt)
Hello Xiang,
As Marc said you should type into the file /install/conf/server.xml the following:
<Connector port="8443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" SSLEnabled="true" URIEncoding="UTF-8" keystoreFile="c:/Java/jdk1.6.0_33/bin/.keystorefile" keystorePass="keyname" keyAlias="/secure"/>
If you don't want to use SSL you have to remove the lines "keystoreFile" and "keystorePass".
Also you ought to have a proxy server in front of JIRA server to redirect https://203.120.121.167/secure request to https://203.120.121.167:8443/secure . You can set up an Apche server with AJP connector that translates every resquest on port 8443. You can check out it how to configure.
Hello Xiang,
please see under {application-directory}/conf/server.xml
<Service name="Catalina">
<Connector port="443"
maxThreads="150"
connectionTimeout="20000"
When you change the port in connector-configuration your Tomcat need a reboot.
A better way is to install a apache webserver in front. The Apache does handle SSL and proxy any permitted request to 127.0.0.1:8080 (HTTP only).
Best regards
MarC
Hello Xiang,
maxThreads="150"
A better way is to install a apache webserver in front. The Apache does handle SSL and proxy any permitted request to 127.0.0.1:8080 (HTTP only). Your firewall allow only port 443 for accessing from outside.
Best regards
MarC
hi marc
i change the port, it doesn't direct to jira.just tell me i can not access the folder.
can you tell me the details on how the Apache handle ssl.
thanks in advance.
Hi, can you confirm if the firewall is open on port 443? I wouldn't really introduce Apache with just one instance. It introduces overhead for no reason.
The config MarC provided should work. Maybe you can post your server.xml if you've made other changes.
