jira api: how to search issues for strings in project
Dennis Chin
March 31, 2020
Hello I am trying to search for a strings within my project using the REST api but can't really understand the doc... For example I want to search for issues in the project CO and the summary must contain *test ssl*. Im expecting some payload that shows last updated etc..
Daniel Ebers
March 31, 2020
Hi Dennis,
welcome to Atlassian Community.
You are on the right track.
Which section of the documentation is unclear to you?
Based on this example section you will have to adjust the jql= part to query for what you are searching (for example the summary).
The response then should be similar to the one in the example section.
Daniel
Dennis Chin
March 31, 2020
So looking at the example :
curl \ -D- \ -u admin:admin \ -X POST \ -H "Content-Type: application/json" \ --data '{"jql":"project = QA","startAt":0,"maxResults":2,"fields":["summary","key"]}' \ "http://localhost:8080/rest/api/2/search"
But let's say I wanted to search for the string "test ssl" in the  summary how would I do it?
Daniel Ebers
March 31, 2020
It should be not more complicated like this:
POST: /rest/api/2/search
body:
jql: "project = TEST And summary = example",
maxResults: 1000,
startAt:1000
Daniel
Jan-Willem Aikens July 5, 2021
Hi @Daniel Ebers
I'm having issues with this as well.
I'm trying to post a jql query. This works --data line is important here:
curl -D- \
-u PERSONAL_DATA_REMOVED \
-X POST \
-H
 --data '{"jql":"summary~\"Testing\"","startAt":0,"maxResults":50,"fields":["id","key"]}' \
"https://localhost:8080/rest/api/2/search"
But when I replace the data with this it does not (it returns no results. I know for a fact there is an issue containing it:
  --data '{"jql":"summary~\"Testing mail for user: mail@domain.com 2021-07-05\"","startAt":0,"maxResults":50,"fields":["id","key"]}' \
Could you please advise?
Thanks very much.
Jan-Willem.
Daniel Ebers
July 11, 2021
Hi @Jan-Willem Aikens
this looks good! I cannot spot any obvious mistake. Moreover I tested it with this Summary on my instance but it gave me back this very one issue - so I cannot figure out why it should not be working for you.
Is the user you are authentication with having permissions on this issue?
Can you open it through Jira itself (user interface) instead of API?
Daniel
Help us plant more trees
