jira connector HTTPS not working
Malik Chettih
in my server.xml, I have these two connectors :
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8453"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
<!-- proxyName="fr1cswpsktp0001.misys.global.ad" proxyPort="80" -->
<!--keyAlias="jira2" keystoreFile="/pathTo/jira-keystore.jks" keystorePass="xxxxx" keystoreType="JKS" -->
<Connector SSLEnabled="true" acceptCount="100" clientAuth="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false"
keyAlias="jira2" keystoreFile="jira2-keystore.jks" keystorePass="cashflow" keystoreType="JKS"
maxHttpHeaderSize="12288" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8453"
protocol="org.apache.coyote.http11.Http11NioProtocol" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`&quot;&lt;&gt;"
scheme="https" secure="true" sslProtocol="TLS" useBodyEncodingForURI="true"/>
The Jira server run properly but for each call from the browser (using http and https url), I get http code 500 and I have this in server log :
08-Mar-2024 17:21:59.879 SEVERE [http-nio-8080-exec-1] org.apache.coyote.http11.Http11Processor.service Error processing request
java.lang.NullPointerException
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:341)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:389)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:926)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1791)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Unknown Source)
08-Mar-2024 17:21:59.880 FINE [http-nio-8080-exec-1] org.apache.coyote.AbstractProcessor.setErrorState Error state [CLOSE_CLEAN] reported while processing request
08-Mar-2024 17:21:59.880 WARNING [http-nio-8080-exec-1] org.apache.catalina.connector.CoyoteAdapter.log Exception while attempting to add an entry to the access log
at org.apache.catalina.connector.CoyoteAdapter.log(CoyoteAdapter.java:487)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:419)
08-Mar-2024 17:21:59.892 FINE [http-nio-8080-exec-1] org.apache.coyote.AbstractProcessorLight.process Socket: [org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper@3050be2f:org.apache.tomcat.util.net.NioChannel@6bdb1028:java.nio.channels.SocketChannel[connected local=/10.21.225.251:8080 remote=/10.21.225.251:63408]], Status in: [OPEN_READ], State out: [CLOSED]
08-Mar-2024 17:21:59.893 FINE [http-nio-8080-exec-1] org.apache.coyote.AbstractProtocol$ConnectionHandler.release Pushed Processor [org.apache.coyote.http11.Http11Processor@42128066]
Tinker Fadoua
Hi @Malik Chettih
Based on what I am seeing on the log file, the following is what was suggested to people experiencing the same issue
https://stackoverflow.com/questions/41690854/server-http-nio-8080-exec-7-org-apache-coyote-http11-http11processor-service
Let me know if the suggested solution worked if not let's check further.
Best,
Fadoua
Malik Chettih
May 17, 2024 edited
Hi Fadoua,
Thank you for your reply, the issue was a simple error in xml file with a double closing tag  </Service>.
Strangely, tomcat server starts properly even with such issue in its configuration file but fails to deploy Jira.
Like • Tinker Fadoua likes this
Tinker Fadoua
@Malik Chettih  Glad to learn you were able to fix it.
Best,
Fadoua
SERVER
VERSION
9.9.0
Register today
