jira data extract into excel
Herman Burema
June 16, 2015
Midori
July 18, 2016
Short answer: Better Excel Plugin!
(In some cases, even the built-in limited Excel exporter feature may fit the bill.)
petry
June 16, 2015
Hey Herman,
Not sure if I completely understood your question, but you can export your JIRA results to Excel:
https://confluence.atlassian.com/display/JIRA/Exporting+Search+Results+to+Microsoft+Excel
Hope it helps!
Andre
Rodrigo Rosa
June 16, 2015
Hello Herman,
What kind of data do you wish to extract to Excel?
For example, if you need to export search results, you can use this document as reference. If you need something else, please let me know so I can provide you more info.
Rodrigo Rosa
