Where is a chart of the meanings of the icons in Jira? I have no idea what a red square with a circular hole means, for example.
Hi Brian,
you can watch all of your icons and types by following admin url:
https://jira.yourdomain.tld/secure/admin/ViewIssueTypes.jspa
There you have to edit one of the types
Then you should be able to choose an image:
https://jira.yourdomain.tld/secure/popups/IconPicker.jspa?fieldType=issuetype&formName=jiraform
Then you'll be able to see each type and referenced image.
Hope this helps.
Mario
Hi, I although have a question to the JIRA Icons: Is there a possibility to see this icon-list without beeing an admin? I can not open your link. Is there a pdf or something similar?
Thanks. Joachim
Thank you!
There is no way I ever would have found that using help menus.
You're welcome Brian. I only knew because i had to search for it a time ago. :) Cheers, Mario
