jira import file
parsdanisun February 25, 2015
I have difficulty in entering the backup file in jira
java.lang.IllegalArgumentException: Timestamp format must be yyyy-mm-dd hh:mm:ss[.fffffffff]
at java.sql.Timestamp.valueOf(Timestamp.java:235)
at org.ofbiz.core.entity.GenericEntity.setString(GenericEntity.java:317)
at com.atlassian.jira.action.admin.OfbizImportHandler.parseValue(OfbizImportHandler.java:309)
at com.atlassian.jira.action.admin.OfbizImportHandler.startElement(OfbizImportHandler.java:213)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.restoreData(DefaultDataImportService.java:865)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:676)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:278)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:66)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:29)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:179)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
plze help me
tnx
Jaime S
February 25, 2015
Hi, Yosef.
What kind of import you're doing?
JIRA seems to be complaining about date format. If it's a CSV import, you can set the date format on importing. It seems that it should be 'yyyy-mm-dd hh:mm:ss'.
Jaime Kirch da Silveira
Atlassian Cloud Support
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
