Sign up Log in
jira.permission.comment.user = false as property on workflow status does not work
Paresh Gandhi
July 30, 2014
it does not disable both comment buttons
Jira - 6.2
Ref:
https://confluence.atlassian.com/display/JIRA/How+to+deactivate+comments+for+closed+issues
Pedro Cora
July 30, 2014
Use jira.permission.comment.user = denied instead of false ;)
Paresh Gandhi
July 30, 2014
Did not work :(
Pedro Cora
July 30, 2014
What is the version of JIRA? I tested on JIRA 6.2.7 and it works.
Paresh Gandhi
July 30, 2014
My bad - it worked without any issue.
Danilo Conrad
December 15, 2014
Setting the property either to false or denied work. On JIRA 6.3.9+, setting this property will prevent comments on transitions which go to the step/status with this property, due to the bug https://jira.atlassian.com/browse/JRA-40997.
Shahriar
@Pedro Cora , this does not work for me in "transition property". it works only in step properties status. I am trying to hide the comment during a particular transition period screen.
Gregory Riccardi April 16, 2020
None of these seem to work in 8.3 is there a page the just lays out all the status proprieties I can use?
Jesse Ontiveros
I agree, we should have this listed out somewhere.
Deleted user June 8, 2018
is not working for JIRA version 7.6.4, any idea ?
Davida August 30, 2018
I try jira.permission.comment.user ->denied  and  works fine! in Jira 7.6.7
Sergio October 8, 2020
What's about latest cloud version?  Nothing working.
Nikola Bornová October 16, 2018
Does this apply also to properties of transitions too? I want to hide Comment field on the transition screen, but none of the Properties below didn't work (in Jira 7.8.2)
jira.permission.comment.denied = true
Also, none of the other suggested solutions  with javascript etc. didn't work, it's quite weird that such simple thing as to hide field on the transition screen is so insanely complicated...
Jacek Klimczak November 5, 2019
Hi Nikola,
try with this:
jira.permission.comment = false
it's working for me
Jacek
Shahriar
Hi @Jacek Klimczak ,
jira.permission.comment = false does not work for me in the transition property.
Sergio June 12, 2021
@Shahriar use this: jira.permission.comment.denied=true
Shahriar
@Sergio , I tried but it doesn't work. I am trying to hide the comment field during the transition screen.
Sergio June 13, 2021
@Shahriar you need to set the property. I use automation for this and it working.
