Sign up Log in
jira.permission.editable.xxx as Step Property
Marco Colageo
Hi Community,
I'm developing a workflow introducing custom editable rules when reaching specific statuses.
For istance, I would like that only a Project Role called "SPR Manager" is allowed to edit the issue which is in a 'For Review' Status.
I implemented something similar for the 'Closed' status, as follows:
jira.permission.editable.group = jira-administrators
This restricts the edit right to the Jira Administrators only. That works great!
So I tried the following property unsuccessfully:
jira.permission.editable.projectrole= SPR Manager
Then, I tried using the project role ID (retrieved form the URL of the Project Role edit page) unsuccessfully again...
jira.permission.editable.projectrole= 10103
Any suggestions?
Many Thanks
Marco
6 votes
Christian Czaia [Decadis AG]
June 2, 2013
Try: jira.permission.edit.projectrole = 10103
BTW @jobin, this is one of the most valuable pages for JIRA admins... Thx Jobin!
BTW: I'd put that property on every "final" workflow step (instead of jira.issue.editable = false / JIRA default)
jira.permission.edit.group = jira-administrators
That way an admin can still perform bulk-updates on "closed" issues :-)
Marco Colageo
Hi Christian,
I had already tried that. It did not work.
Cheers
Jobin Kuruvilla [Adaptavist]
June 2, 2013
@Christian Glad it is useful :)
June 2, 2013
You will have to use the id only. Can you make sure the project role had Edit permissions before you limited it in the Closed state?
If the role is not already in the permission schemes, this wouldn't work. Also see http://www.j-tricks.com/1/post/2011/02/permissions-based-on-workflow-status.html
Marco Colageo
Hi Jobin,
thanks for your reply.
The edit right is assigned through the Permission Scheme to:
  • - Reporter
  • - Current Assignee
  • - Administrators (project role)
Then, at project level I customise the 'SPR Manager' project role adding two users, which are not necessarily the Reporter, the Assignee nor an Administrator.
I would expect the...
...giving the 'super-edit-power' to those two users.
Is that feasible somehow?
Cheers
Marco
June 2, 2013
AFAIK the edit permission is the ground level permission. So people in your SPR Manager role can only edit the issue if they are either reporter, assignee or administrator...
June 2, 2013
@foxiceit You cannot do this. You should have the project role 'SPR Manager' in the permission scheme. You can add/remove users from it at any time but the restriction will work only if it was there originally.
In short, you can restrict permissions but cannot grant new permissions.
Raju Adluru
June 20, 2014
Jobin
thanks for j-tricks and help in forums
jira.permission.editable.projectrole and groups = xxx
above property and values are working only when user is not in a group, which is not added to Edit issue permission.
i have a scenario where user or group or role should not be able to edit only in one workflow status, in other status they should be able to edit.
can somebody help me with this, how to restrict a user/group/role from editing a issue in one status.
thanks
June 20, 2014
On the status, restrict the permission to a group or role where the user is not a member of!
Raju Adluru
June 22, 2014
Jobin
If i do that, that group is cant edit issue at all. but i want to restrict group only on that status, can we do this?
that group should be able to edit issue except in that status, for e.g, epic should be editable for a group, when epic is finalized, that group should not be able edit epic. can we retrict same group which has edit permission, not to edit in a status?
only allow admins to edit.
June 23, 2014
If you are using the workflow property only on that status, you should be able to edit everywhere else. Not sure why that is not working.
Raju Adluru
June 24, 2014
I have added workflow property on that status, it is not working, it is allowing other group users to edit the issue, who has edit issue permission.
Michal Crkon July 2, 2013
Yes, there is this group and i am part of it. I tried also jira.permission.edit.user = EMICCRK with true/granted or without with the same result. Of course I added extra my name to the permission scheme for editing.
Michal Crkon July 14, 2013
i solved the problem, finally. property key is jira-permission-edit.group and property value is jira-system-admin. Even now i created a new group xxx with 2 member. i added this group to permission scheme in edit issue. now only this group may change the issue when is closed. They do not need to be in admin position.
Guys, it is strange. When i run this on test environment i have no problem, everything goes like from the book. But if i put the same changes to the live environment i am getting the same error: *Error rendering 'com.atlassian.jira.jira-view-issue-plugin:details-module'. Please contact your JIRA administrators.* What is going on? Does someone know how to fix it? I am trying to play with this and problem seems to be in the line *jira.permission.edit.group = jira-system-administrators * Thanks for any help. Miso
July 2, 2013
Do you have the "jira-system-administrators" group in your production environment and / or are you part of it?
July 2, 2013
Look in the log files. I am guessing there is a plugin that is blown up when there is a permission issue.
Michal Crkon July 1, 2013
hi guys,
i am trying to make close issue editable with permission for administrator. I tried http://www.j-tricks.com/1/post/2011/02/permissions-based-on-workflow-status.html and also jira.permission.edit.group = jira-system-administrators with granted. I am getting errors says :
all my tries :
Property keyProperty value
jira.permission.edit.group = jira-system-administratorsgranted
jira.permission.edit.projectrole=10002
jira.permission.edit.projectrole=10002granted and true also
jira.issue.editable.users = emiccrkgranted and true also
I am getting above error msg or it is editable for everyone.
my permission scheme for edit issue is
  • Project Lead
  • Project Role (Administrators)
  • Project Role (Project Managers)
  • Project Role (Developers)
  • Project Role (Reporters)
  • Can someone help me? thanks. Miso
July 1, 2013
Just try jira.permission.edit.group = jira-system-administrators. Make sure they could edit before as well.
July 1, 2013
jira.issue.editable should be true by default. No need to give that explicitly.
It is working but it needs to keep both lines of permission:
jira.permission.edit.group = jira-system-administrators with no property value
jira.issue.editable with property value true
always i tried only one of them or crazy combinations. Thanks a million, Miso
We had jira.issue.editable false by default.
July 1, 2013
I am sorry, by default I meant that it is true if that is not explicitly set ;) You can just remove it for example or set it to true as you did.
