jira restore import from xml backup nullpointerexception
Stephen Gidden
November 21, 2017 edited
attempt to import zipped backup from other instance.  new instance, maybe no users except admin.  aT 21%, nullpointerexception
zip file follows advised format of content - it is an unaltered backup.
want to import to cloud.  unknown source version (timeframe = March/17)
advice?  suggestions?
Suhas P
November 21, 2017
Make sure while taking backup, no users are logged in. If any logged in user is updating jira while taking backup might corrupt backup taken,
To ensure all users are kicked out, shut down first and start jira on different port. Then take backup and try once more.
Good luck.
Nic Brough -Adaptavist-
November 21, 2017
There are a number of export/import issues you could be hitting.
Could you give us the version of Jira you exported from and the whole error message?
Although, you do mention March/17, which strongly suggests a version of Jira far too old to export from if you're going to import it into Cloud - you should have upgraded to at least Jira 7.5 before export.
Read the story
