Sign up Log in
jira suite utils - appending to a custom field
Richard Jones October 10, 2015
Hello
I have a multi line text custom field. I want it to contain the number of times a bug has been reopened. I tried to get it to increment a number by 1 each time but this isnt supported. I thought about then just putting x into the field each time it is reopened. the number of x in the field would indicate the number of times it is reopened.
I tried putting 'x' into the field and set appending but it only ever sets x. It doesnt append. Same for current datetime. It does however work for current_user.
Can I get x to be appended?
And a separate question is can I get concatenate these things? Is it possible to get current user and current date time both appended to a field?
Thanks in advance. Im really liking JIRA suite utils so far!
Fabian A. Lopez (Community Leader - Argentina, Florida, California)
March 28, 2018
I had a similar situation and I ended creating a numeric field, purchasing the Add on Jira Misc Workflow Extension  (JMWE) to use the transition that increments the value of a numeric custom field in one unit.
I didn't find a solution out of the box
Deleted user October 12, 2015
Why use a Multi Line text field? Can't you use a numeric field? And yes, you can set custom field values programmatically (take the current value then add something to it). Take a look at the JIRA ScripRunner.
Register Now
Upcoming Jira Events
