You can find the functions to use for multiple ways of looking at commits, builds, etc... from thsi page.
Hope this helps
Subversion ALM does the job:
https://marketplace.atlassian.com/plugins/com.kintosoft.jira.subversion-plus
even you can get issues with more that one, two, three or any amount of commits.
I don't see any problem in that. They are different products. Simply, you have requirement/need and Subversion Plus resolves it in a fashinon way. Not only this, it really answer any question requiring mixing JIRA (project, status, priority, ...) with Subversion (commit date or number, author, comment, file or directory,..) attributes. Furthermore, other stuff features like browsing on Subversion, etc.
Not conviced? Then wait for the coming 6 version ;)
Version six, I meant.
Hi again,
it is free:
https://marketplace.atlassian.com/1211642
and now the commit graphs have also been improved to display JIRA issues. I would say there is not any tool (including desktop tools) able to provide such traceability.
I'm just experimenting with the script runner plugin. Does anybody has a clue how the script for get last commit id could look like?
Could be done with my not-yet-released scripted custom fields maybe. The result from that can be stored in the index as a string (changelog comment) or int (changeset id), which would make it queryable.
Hi Francis. Well, in the svn plugin code there are methods for getting issues with commits for particular projects, so I'd look at making that into jql functions. With fisheye I don't think it's possible as AFAIK nothing is stored in the lucene index, so this sort of query really needs to be made from fisheye. Everything with fisheye is "ondemand", ie, when you look at the source issue tab panel, a rest query is made to fisheye. Maybe you could write a jql function that uses the rest api, but i imagine this would be slow.
How are you integrating with the VCS... eg if using the jira-subversion plugin it feasible, as the commits are indexed. But if using fisheye I doubt it is possible.
Save your spot
