Hi
My goal is to selcet tasks and sub tasks from some epics
The following query works
( status = "To Do" OR status = "In Progress" ) AND ( parent in (TEST-4554, TEST-4553, TEST-3637, TEST-4552, TEST-4538, TEST-4550, TEST-4551))
Now if I would like to have something more dynamic, I would like to select directly from a dynamic pool of epics.
Make a filter "myEpics"
project in (TEST) AND issuetype = Epic AND labels = NiceLabel ORDER BY priority DESC, updated DESCAnd then run the query in the following way
( status = "To Do" OR status = "In Progress" ) AND (parent in (filter = "myEpics") OR "Epic Link" in (filter = "myEpics"))It is not working, I think because (filter = "myEpics") is not evaluated first and it doesn't return a list
What do you think about?
I'm afraid it's impossible to do this with system tools. You can try Scriptrunner, check out this question: https://community.atlassian.com/t5/Jira-questions/Feeding-filters-into-other-filters/qaq-p/1118145
