I am trying to figure out a jquery for all jira issues in all projects i updated within a date range. This is something i am trying to put into a report that will be used weekly (changing the date range every week). suggestions?
I can see how to search by date and by project/etc but i have no updatedby() in jquery.
I think i figured it out. it at least seems to be working:
(reporter = MYUSER OR assignee = MYUSER OR issue.property [comment] = MYUSER) AND updated >= 2019-12-02 AND updated <= 2019-12-06 ORDER BY created DESC That way for a certain week, i can look back multiple weeks and see ONLY the data for that week.
Hi @c4mmartin ,
you can use something like this :
project = "YOUR_PROJECT_HERE" and updated > startOfWeek() and updated < endOfWeek()
Using this approach you don't have to update filter every week.
Hope this helps,
Fabio
Problem with the date is based when the report is looked at it will only show the current week and not the week i am trying to target for instance:
AND updated >= 2019-10-18 AND updated <= 2019-10-22
if you wnat to get issues from all project you can use just "updated" in your jql:
Ciao,
Fabio
I am trying to return from all projects, every issue i had touched (created, modified, commented on, added attachments, closed, updated in some way) within a certain date range
For now i am just doing:
reporter in (MYUSERNAME) AND created >= 2019-11-4 AND created <= 2019-11-8 ORDER BY created DESC
which only gives me issues i created, but not any issues that i had worked on.
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
