license jira upgrade from 4.4.3 to 5.1.8
cisco December 11, 2012
We are trying to upgrade our Jira version from 4.4.3 to 5.1.8
But what we are seen on the screen is the need to upgrade the license, is strictly necessary?
The message is : "The current license is too old to install this version of JIRA"
Waiting for a feedback,
Kind regards.
Jobin Kuruvilla [Adaptavist]
December 11, 2012
Yes, you will have to generate a new license for JIRA5 and apply that. You can do it pretty easily from my.atlassian.com. Check out licensing FAQ for moew details.
Renew | Upgrade | Download JIRA | Download Source | View Developer License
which of those?
is it free of charge?
Nic Brough -Adaptavist-
December 11, 2012
Depends on what you've got already.
The license you were using allows you support and upgrades during the period you have paid for. After that period, you can upgrade to any version of Jira that was released before your license end-date, but not afterwards. For example, if your licence is expired between the release dates of Jira 5.1 and Jira 5.2, you could upgrade to 5.1 but not 5.2. I suspect that's what's happened to you, and you'll need a new licence.
I'd choose "renew" from the options to begin with - that makes it clear that you're trying to renew rather than buy a fresh one, but if you've not paid maintenance for a long time, you may need a new one. The renewal process should tell you (and prompt a conversation with Atlassian if needed)
thank u so much
