Hello. look at the picture please. You can see the state Info needed. there are two possible ways to get int this state: when issue is opened by test manager and TM requests more info from reporter (transition "add more info reporter"), or by transition "fill more info" from the state "in progress".
Question: how can i determine, that when you came from state "in progress" to "info needed", you can only come back via transition "answer" and the transition "info doplnene" wouldnt be available?
and vice versa: when i make transition "add more info reporter" into state "info needed" from state "open", i would like to have only possibility to come back to state open via transition "info doplnene".
thank you very much
Use the "Previous status" condition in JIRA Misc Workflow Extensions plugin.
that plugin is great, thank you :)
