×I have a text custom field and would like to limit it to 70 characters or less. Is there a way to do this so whenever this field is present on any screen it only allows 70 chars?
if you have Adaptivist Scriptrunner you can develop a behavior or validator. If you do not have Scriptrunner you can download JsIncluder plugin (https://marketplace.atlassian.com/plugins/ru.mail.jira.plugins.jsincluder/server/overview) and write custom javascript for create, edit and view screen.
Hello Alexey,
I currently use a regex validator in the workflow as follows:
[A-Z a-z 0-9 ,.-]{1,70}$
However I dont like this method. Also the error message is ugly (See attached).
OK. It s also a solution :)
I will also try it. Thank you
I am using behavior plugin
def field = getFieldByName("My Field Name")
if ((field?.value as String)?.length() > 70) {
field.setError("Length of the field should be less than 70 chars")
} else {
field.clearError()
Do you receive an answer concerning your question?
You can add condition to your workflow and check that the max number of char is below 70.
Or you can create your own script field.
Hello. You can resolve this by adding a regular expression check to the workflow transition. Much simpler than a groovy script.
Go to Project Setting > Workflows
Edit the workflow for the affected issue type
Switch to Diagram mode
On Create transition, click on the Validators
Choose Add Validator > Regular Expression Check
If you would like to restrict the field to a specific length: enter [0-9]{n}$
(n) reflects your desired field length.
Neither of these options stop a user from changing the field AFTER doing the transition though as they both depend on a transition validation.
I was looking for something similar and it seems that if we can't absolutely stop a field EVER being longer than a certain length then there is little point restricting it SOMETIMES.
Ah, correction. It seems that BEHAVIOURS do apply at all times - looking into that now.
Question, I have a single line text field that I have set up a Validator in a workflow transition to verify the text entered is only up to 200 characters long (below). But it is not working. Even if I enter just a couple of words in this field, I will get an error message below. Is it because it is a text field that allows spaces? I'm stumped
Regular Expression Check (JSU)
