Hello Team,
Is there a way we can log time spent on a jira issue directly through dashboard?
Regards
Priyanka
there are no gadgets (AFAIK) that allow for direct input.
@Jack Brickey IS there any workaround for this? Please advice. The client does not want to go to every issues and fill the time spent.
Regards
Priyanka Khare
I recommend researching the Marketplace. Here is one option I found with a quick search - ezee-worklog
