make a comment visible by a user of my choice
Hanae alahcen
hello ,
How can i share a comment with users of my choice ?
in the list i find ( All users , devellopers , users )
Alex Perez
July 1, 2013
you (the user editing the comment), must belong to that role in order to change it's visibility to that role.
Hanae alahcen
i discover that if i want this role to be active i have to put it all the projects :/ we have actually 820 so wish me a good luck :)
Nitram
July 1, 2013
For Your Information, you can look into this, https://confluence.atlassian.com/display/JIRA/Commenting+on+an+Issue
Hope this helps.Thanks!
Hanae alahcen
hello
thanks for your informations
Alex Perez
July 1, 2013
Scripting is the path, unless you want to visit each of the 800+ projects :)
HTH
Hanae alahcen
i don't have the ability to script :s so i'm gonna do it myself and manually
Hanae alahcen
i've created a new Role in wich i set all users for i want my comment to be showed
what should i do to have this role in the selected list ?
