In the current release of the Configuration utility the mappingValuesJiraToTfs (and mappingValuesTfsToJira) doesn't populate.
What is the XML format for these items, so I can add them to the XML to be saved in the work item synchronizer?
Have you looked at the work synchronizer sample XML file in client app directory ( default: C:\Program Files (x86)\UseTFS )? It contains the sample mappings.
Basically it's a dictionary structure so for example:
<UseTfsField> <tfsName>System.State</tfsName> <jiraName>Status</jiraName> <limitSynchToDirection>Both</limitSynchToDirection> <mappingValuesTfsToJira> <UseTfsPigstyDictionary> <key>Active</key> <value>Open</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>Resolved</key> <value>Resolved</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>Closed</key> <value>Closed</value> </UseTfsPigstyDictionary> </mappingValuesTfsToJira> <mappingValuesJiraToTfs> <UseTfsPigstyDictionary> <key>Open</key> <value>Active</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>In Progress</key> <value>Active</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>Resolved</key> <value>Resolved</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>Closed</key> <value>Closed</value> </UseTfsPigstyDictionary> <UseTfsPigstyDictionary> <key>Reopened</key> <value>Active</value> </UseTfsPigstyDictionary> </mappingValuesJiraToTfs> <defaultIfNull>true</defaultIfNull> <fieldDataType>TEXT</fieldDataType> </UseTfsField>
