membersOf function
Peter Milakovich
February 24, 2015
JIRA Advanced Search - membersOf function
Is there a way to modify the membersOf function or create a mirror function that looks at Tempo Team instead of JIRA Group?
Viưar Svansson [Tempo]
February 24, 2015
Hi Peter,
There is a Tempo function - team(), that you can use:
assignee IN team("The A Team")
Vidar
Natalie White March 6, 2019
Does this only work in Tempo Server? Or does it work in Cloud as well? I am in Cloud and can't get the function to work.
Lukas Maag
September 18, 2019
assignee IN team("The A Team") does not work see below...
Susanne Gƶtz [Tempo]
February 24, 2015
Hi Peter,
it is not possible to use the Tempo Team quite in the same way as membersOf, but if you have set the Tempo Team Custom field on your Issue screen, you can filter by Issues linked to the Team (https://tempoplugin.jira.com/wiki/display/TEAMS/Teams+Custom+Field). It is not possible to sort by f.x. assignee that is a member in Team X.
To filter issues by Team set in the Team Custom field in jql, you can use:
Team = "TeamName"
Susanne
