Hi all, I've read through the documentation and not sure I found exactly what I was after so asking here is the next step!
Our current configuration is Data Centre on 2 nodes in AWS.
Q. Once the full re-index is done on 1 node, will the index automatically copy to the 2nd node or does that only happen when a node is re-added to a load balancer? or are we best to use the 'Copy the Search Index from another node' option during our organised outage window.
Q. When a new node is created, does that node get a fresh index from the db or would it copy it from an existing node?
- Is the idea possible?
- Anyone configured anything similar?
thank you, Craig.
Hi @Craig McCall ,
Please take a look to the following doc https://confluence.atlassian.com/jirakb/how-to-reindex-jira-data-center-without-downtime-757467576.html
Hope this helps,
Fabio
