nginx serving jira and stash
Daniel Urstöger
Hi guys,
I run jira and stash on the same server and use nginx as a proxy for SSL support. Every instance for itself works perfectly, but when I try to link jira with stash via "Application Link" I get an error: The host doesn't respond. Change the URL or click Next to confirm.
Parsing through the web browsers error log I found that the problem seems to be that nginx doesn t support http OPTIONS. Which seems to break this specific feature.
I googled and I found this work around:
error_page 405 =200 @405;
location @405 {
root /;
proxy_pass http://127.0.0.1:8080;
Which didn t help in my case. So I wonder what would be the proper way to make jira and stash work completly behind nginx?
Daniel
PS: here is the complete config file:
server {
    listen       80;
    server_name  jira.gosi.at;
    rewrite      ^ https://$server_name$request_uri? permanent;
server {
    listen       443 ssl;
    ssl_certificate  ssl/gosi.pem;
    ssl_certificate_key  ssl/gosi.key;
    location / {
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Server $host;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        port_in_redirect off;
        proxy_redirect http://127.0.0.1:8080/ http://jira.gosi.at/;
        proxy_redirect https://127.0.0.1:8080/ https://jira.gosi.at/;
    location @405 {
        root /;
mfentross
July 9, 2014
Any other sugestions on this one? I am having the same occurence.
Sebastian Knoche
October 20, 2013
If you use self-signed certificates or certificates issued by your own CA you have to trust them within the JRE running the Atlassian product(s).
Just take a look at:
https://confluence.atlassian.com/display/DOC/Connecting+to+LDAP+or+JIRA+or+Other+Services+via+SSL
Dave Theodore [Coyote Creek Consulting]
I've had similar troubles with nginx as well and ended up resolving it by using apache/mod_ssl/mod_rewrite I think nginx does not rewrite headers properly in some cases, but I never was inclined to troubleshoot it to find out for sure.
EddieW
August 5, 2013
I am not sure that fix will work as you hope.
Have you tried the resolutions to enabled
if ($request_method = 'OPTIONS') {
add_header 'Access-Control-Allow-Origin' 'YOURDOMAIN';
add_header 'Access-Control-Allow-Credentials' 'true';
add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS';
Daniel Urstöger
Thanks for your input, I change the config to this:
server {
    listen       80;
    server_name  git.gosi.at;
server {
    listen       443 default ssl;
    location / {
        proxy_pass http://127.0.0.1:7990;
        proxy_redirect http://127.0.0.1:7990/ http://git.gosi.at/;
        proxy_redirect https://127.0.0.1:7990/ https://git.gosi.at/;
            add_header 'Access-Control-Allow-Origin' 'git-rso.rapidsoft.de';
For both the Stash and Jira config, sadly this didn t help.
EddieW
August 7, 2013
Just for sureness, change the
to
add_header 'Access-Control-Allow-Origin' '*';
Daniel Urstöger
Hi there,
thanks for that, well I have two Installations. One is my play field and the other one the production setup.
If you could please remove the posting with git-rso, that would be great.
I played around with the config a lot and copy pasted one version which was not the latest I tested, I actually it was like this:
server {
    listen       80;
server {
    location / {
            add_header 'Access-Control-Allow-Origin' 'git.gosi.at';
That didn t work. When I get back in the office, I will try with * as well!
Register now
