I'm trying to move an issue from story to bug. In our bug definition a custom field called foundin is required.
However during the move screens the foundin field does not present a dropdown even though it is a single select custom field.
When I press the button to move it JIRA complains that foundin needs a value and will not let me proceed.
Why is there no drop-down so that I can change foundin to a value?
Do you mean that it only happens on bulk edits? Does it affect native version picker fields such as affects version or fix version?
I just noticed this happens on bulk edits.
No errors in the JavaScript console. It happens in all environment(test/production) and in chrome and IE. It seems to be happening only with version picker fields. The field is only applicable to the bug issue type.
Does this happen across all browsers? Does it happen with any other fields? Can you reproduce it in a different project if you add the field there? Can you reproduce it in a staging environment? Do you have any errors in your browser's Javascript console?
Learn more
