Hi everyone. We have a script what create a subtask, but doesn't works a change of assignee in parent's task.However we see in the history that a assignee was changed. Could you please to help us to find decision of this problem.
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def customFieldManager = ComponentAccessor.customFieldManager
def localizationField = customFieldManager.getCustomFieldObjectByName("Localization")
def config = localizationField.getRelevantConfig(issue)
def options = ComponentAccessor.getOptionsManager().getOptions(config)
def changeHolder = new DefaultIssueChangeHolder()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueService = ComponentAccessor.getIssueService()
def subTaskManager = ComponentAccessor.getSubTaskManager()
def constantManager = ComponentAccessor.getConstantsManager()
def issueManager = ComponentAccessor.getIssueManager()
def createValidationResult = issueService.validateSubTaskCreate(currentUser, issue.getId(), issueInputParameters)
if (createValidationResult.isValid()) {
def createResult = issueService.create(currentUser, createValidationResult)
if (createResult.isValid()) {
subTaskManager.createSubTaskIssueLink(issue, createResult.getIssue(), user)
issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.setAssigneeId("mrk.localization")
.setComment("Sub-tasks were created")
def updateValidationResult = issueService.validateUpdate(currentUser, issue.getId(), issueInputParameters)
if (updateValidationResult.isValid()) {
issueService.update(currentUser, updateValidationResult)
Hi alex,
Usually when I had this kind of issue in the past it was linked with reindexing issue after update.
Would you try to use the following class: https://docs.atlassian.com/jira/7.3.5/com/atlassian/jira/issue/index/IssueIndexingService.html#reIndex-com.atlassian.jira.issue.Issue-
That should be something like:
IssueIndexingService iis = (IssueIndexingService) ComponentAccessor.getComponent(IssueIndexingService.class);
iis.reIndex(issue);
Let me know if it works!
