notification and custom field
guis January 29, 2013
I have a problem. I have a custom field email. The user create a issue, he indicate his email via the custom field. I would like that JIRA sends a notification to the email address which is specified in the custom field email. How to make the notification is sent to this email?
Best regard,
Guis
Renjith Pillai
January 29, 2013
Sameera Shaakunthala [inactive]
January 29, 2013
Good suggestion.
Add a text (< 255) custom field. Try to retrieve it's value into the groovy script (do some RND). Send the email to that email address using the script upon the create transition.
Renjith Pillai
January 29, 2013
Yes, that's the way.
Thank you for the answer. I have add the post script function and I use the script "send a custom email". But I indicate in the field "To issue fields" my custom field mail, a notification is send but the
notification is not sent to the person indicate in the custom field.
Why?
guis January 31, 2013
How to retrieve the value a custom field with a script groovy? What is a method?
Vladimir Horev _Raley_
February 25, 2016
Use https://marketplace.atlassian.com/plugins/net.vacom.jirassimo/server/overview
to achieve that. Destination can be dynamic and based on the content of your JIRA issue.
Baris Guner
Hi Guis,
I am not sure if you have already solved this problem but at leat for others who stumble upon this check out this :
https://answers.atlassian.com/questions/45722/how-to-use-a-custom-user-picker-field-in-to-issue-fields-when-sending-a-custom-mail-with-script-runner
To find out ID values of your custom fields :
https://answers.atlassian.com/questions/102822/how-can-i-find-the-id-of-a-custom-field-in-jira-5
Finally the free plugin you need :
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Hope this helps,
Baris
January 29, 2013
Didn't think of anonymous access. :)
In this case you will have to look for a custom field plugin. May be you will be able to develop a plugin, which takes an e-mail address as its input and emails the entire issue to that email address.
C_ Faysal
January 29, 2013
if you don't wanna code your own...
https://marketplace.atlassian.com/plugins/com.metainf.jira.plugin.emailissue
will send mails to non-jira users
Thank you but the plugin is paid.
Because the user don't have a account!
January 29, 2013
Why don't you send the notification to the user's email address specified in his user account?
Rahul Aich [Nagra]
January 29, 2013
Can you add it in the notification scheme for create issue event to send notification from the value picked up from the user-picker custom field?
Note: You may have to configure your custom field as user-picker type
Rahul
C_ Faysal
January 29, 2013
Thank you! But the user don't have account JIRA therefor I can't to use the user-picker custom field. How can I send a notification using a text custom field?
The field contains the email address.
Guis
